HELP ! iMac won't boot - stuck at Apple Logo
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
I have Time Capsule and everything is backed up on there. My data is on a separate USB HD + Drobo, but for now I need my iMac to boot but it won't. It won't even get into the Desktop. Any idea how I an restore it? all the guides online says double click the Install Icon this and that...I would if I can get into the Desktop !
It is stuck on the Apple Logo screen with the spinny thing stopped spinning.
Copied from another forum shamelessly
Put in the disk that came with your mac and hold in c while it boots then run a disk check with disk utility, or conversely try DiskWarrior 4, it has saved me on many occasions.
Well, it tries to boot from the disc....hear it spins for about a minute, and then the spinny thing hangs again!!!!
How long do I hold down the C for?
It just won't boot from the Disc...if it doesn't boot from the disc or the HD then how can i get it to boot from the Time Capsule? or can you?
No problem. I first came across the SMC information when I was trying various fan controllers. It was advised to reset the SMC so that it would go back to default after having messed with the fan speeds.
Now I use it for a "pull the battery out of the board to reset the BIOS" version for Mac. :p
I think this happened because i didn't shut down properly on Tuesday when I HAD to go. It took AGES to shut down and I was in a hurry to catch a train so I pressed and held the power button to shut it down...
Wikipedia cites incorrect powering down as a reason, so that was probably it. For future shutdown hanging: if my iMac hangs at shutdown I try option-command-esc to bring up the force quit window if it's still available and close whatever app may be still in there and preventing complete shutdown.
