Help Importing TV series with MP-TV series (StreamedMP)
19 Aug 2009
Cornwall
I can't figure out how to import my TV series into media portal. Movies are fine but TV series won't import. They are all in .vob formats.
I get a list of 460 items and it asks me to input the series info and episode items which would take forever and I doubt I would get it right.
Surely there's an easier way?
Cheers
You need to choose one of the regular/simple expressions that relate to the way your episodes are named, or write your own.
eg. Series name/Season 1/1x01 - Episode_name.vob
You'd use something like %sn/Season %s/%sx%0e - %en.%ext to parse your episodes.
I don't use media portal any more (I switched to Xbmc) so that string won't be exactly right for the above example.
There will be special wild cards you put in
I always name everything..
Series name SxxExx.xxx
I've never had a problem with it detecting anything with them named like that! :)
Bit of a bump.
I had this working and converted a lot of my files to avi. The problem now is that I can't get MP-TV to communicate with the thetvdb.com it worked for a while but now when adding the series and searching for episode data it just says it can't connect.
Any ideas?
