- 13 May 2012
- Dewsbury,West Yorks,uk
Hi guys.
I am moving from corsair com pro's and their lighting nodes and going back to Aquacomputer's Aquasuite (still have license from previous build non rgb) using the Corsair LL120/140mm fans after having nothing but grief with their software.
So finally, i have stripped my Corsair 1000D build down and while i am changing my tubing to acrylic i am just about to start the wiring/connection process of the fans.
Below
RGB & power/PWM parts to be connected to Splitty4's and Farbwerk 360 and Aquaero 6 LTE
Corsair 1000d case (led front glass panel inc reset/power button corsair connection at the end)
21 Corsair LL 120/140mm led fans.2 x 360mm rads front and 1 x 420 rad up top).
Ek Quantum flt360 res (standard 3 pin rgb)
EK Quantum 5900x Amd cpu block (standard 3 pin rgb)
Ek Quantum Trinity Gpu block for Zotac rtx 3090 (standard 3 pin rgb )
EK RGB Quantum flow indicator (standard rgb 3 pin)
Running on a Corsair AX1200i supply
Aquacomputer parts i have are.
1 x Hubby7
6 x Splitty4
2 x Farbwerk 360
Aquaero 6 pro (not using the screen as the 1000d has no bays, so lite ver. taken from my Prev build)
Question, do i have enough Aquacomputer parts to power this ie splitty4s or Farbwerk 360's also usb ports (hubby7) or do i need more.
Could any forum members on here help me in the correct way/order/fan splitters to get these up and running please, it is a big ask but would be app.
It was easier on my old 900D build with non rgb fans, i just used 4x 5 way pwm splitters then straight tom Aquaero 6 fan inputs
Thank you in advance
Below
1 x Hubby7
6 x Splitty4
2 x Farbwerk 360
