Hello, I want to upgrade my ISP's supplied router. I have 500Mbps Internet connection with 3 stories home.
I came across the mesh option such as the Deco M5 or using stronger Router.
Currently my router is able to reach most of my home but some corners are out of range for it.
All I care about is getting high speeds at long range ( I expect 100mbps at farthest point). the rest of the stuff such as parental control, USB,Design are irrelevant.
I came across the Archer C80 and the AX20 from TP LINK. In terms of long range speeds I want to know which one do you think will do the better job for my needs.
Regarding the Mesh option of using 3 Deco M5 units. I read on the Web that the units themselves are not that strong and because the farthest unit will receive horrible speeds(50Mbps of 600Mbps) and its all a trick to add more and more expensive units to the Mesh.
I would very appreciate your honest and professional opinion.
thank you for the help.
