Help installing my new heatsink
23 Mar 2007
Essex
hi
I have just got myself a new cpu cooler for my new phenom II cpu i have the the artic cooler freezer 64,should be with me tomoz i hope
http://www.overclockers.co.uk/showproduct.php?prodid=FG-000-AR&groupid=701&catid=57&subcat=1395
The question i have is i understand that the cooler comes with a bracket you need to attach to the board, my new board came with a bracket pre installed on it which fits the standard phenom cooler, will this artic freezer cooler fit on the bracket that came with the board or will i have to remove it and install the one that comes with it?
This is the board i have
http://www.overclockers.co.uk/showproduct.php?prodid=MB-357-AS&groupid=701&catid=5&subcat=1482
I not know the answer to your question
However I can reassure you that the stock amd bracket comes off very easily. Just pull the pins up.
