Help installing phantek PH-TC14PE
27 Jun 2005
Reading
Hello guys
Iam trying to install my new cooler, replacing my water cooled setup. im at the last stage of installing the phantek cooler but i cannot get the last bolting screw in, its about 1mm out. :( tryed everything thing won't budge.
Any ideas?
Can i return it?
Thanks but i followed a vid on the intel version and followed it step by step, don't think ive done anything wrong.
Okay,
So you've managed to put the first screw in but the second won't go in right?
Does the cooler rest on the mounting bracket okay or does it feel a but unstable?
Hello guys
Any ideas?
Can i return it?
I had this problem when i tried to install this cooler. What you need to do is losen the backplate a little bit so that you can move it a very small amount to line up better. If you do that it will fit. I had exactly the same problem as you initially.
Thanks LtMatt that did the trick! :) Now to get on with the build lol
God damn im a freakin genius hey lad. :D
Congrats mate, its a great cooler and the customer service phanteks provide is top notch. Let us know how the temps are.
Here are my temps on the new Phantek:
Idle - 32c - 36c on four cores
Load, using Prime - 55c - 60c
Im very happy with this result, great cooler, nearly same temps as my watercooled setup !
55-60c, is that at 4ghz on the 930? If so, that is astonishingly good on what are pretty hot running chips.
