Help installing VBulletin
28 Apr 2004
I really need help installing a VB forum. I don't know anything about databases
When I install vb it says "The database has failed to connect because you do not have permission to connect to the server. Please confirm the values entered in the 'includes/config.php' file." What does that mean? I have already set up a MySQL database and copied the databse name in the config file
One thing - on most shared hosting systems if you create a database and call it 'hello' then the actual database name will be [your username]_hello. ie, prefixed with your username and an underscore.
This can apply to the database user, too.
