I just bought a second hand Lenovo Y410p which has a 24GB SSD and a 1TB HDD.
I'm about to do a clean install of Windows 8.1 and I want it to run as quick as possible, so I presume that's what the SSD is for.
I know how to map program files, user files etc. across to the 1TB drive (E
but is this likely to cause me any problems - am I better off installing Win 8.1 to the 1TB drive? If I do that then what's the point of the SSD?
Plus if anyone knows of an easy method to point program files across to the E: drive (the method I found was quite complex as it meant altering the registry), then please share it here.
Any comments or advice very much appreciated - thanks.
