HI
just purchased a IP35 pro XE off the MM. Put the system together and getting a C1 post error reading. This relates to the memory and i suspect that there is not enough voltage on the motherboards default settings to power the ram.
I have tried:
- Reseting the CMOS (removed battery, changed jumpers etc)
- Various combinations of ram in all sockets. (tried different voltage ratings of ram 1.8 and 2.1)
- Tried another graphics card
- Tried a different CPU
- Resat everything multiple times
All components were taken from a working machine. Spec is as follows:
Intel C2D 8400
4gb Kingston HyperX DDR2 8500 (2x2gb)
GTX285
Basically i need to up the voltage i think, but can't boot to change the settings :s
Any suggestions please!
I have tried:
Intel C2D 8400
GTX285
