Help iron out my first time watercooling build before I buy it
7 Jul 2004
Gloucester
This is what I have almost decided on. I have read many reviews & guides etc & have planned this for some months now. As you can see in the pic below I have used OCUK however they are out of stock on some items so I may need to pick them up elsewhere.
2 things I am stuck on: Which is the best anti conductive coolant to use and how do I join my 2 470s together? They are 1 space apart & looking at pics I see some people have a small pipe there but i'm not sure where to find them...
Soo, what should I change/add/remove?
It will all fit in a new 700D case and will cool CPU & both 470s.
As far as I can see, that looks really good mate :) Maybe you would want to get the nickel version of the CPU block to match your VGA blocks, but it's not major :)
The rest all seems ok :)
That's a good idea, cheers.
What do I put between the 2 cards in SLI? or do I just hose them manually as I would with anything else?
Get the bridge and the connectors they are very cheap
+1 - makes your build look allot cleaner. You may also want to purchase some PT Nuke and G12 Coolant (Corrosion Inhibitor) to add to your di-ionised water / feser. Also, is there any reason why you are buying 20 barbs?
They both look good. Which ever is in stock will be the one I grab as long as they perform the same..
Cheers for the input.
Any idea where the SLI bridges can be picked up?
Also 470 waterblocks as here is pre-order & i'd like to order tonight :)
