Help ive forgot
10 Jun 2009
Darlington
Hiya all.
Can someone jog my memory which screws go where on a EK gtx 280 waterblock with backplate.
I have to diffeernent length screws and im sure the longeer one of the 2 are used to attach the backplate. Im right here arnt I.
I cant remember though if i need to use all long ones to attach the backplate and block together or attach the block to the card forst with the smaller screws and use the longer ones to attach the backplate to the block?
I havnt explained that very well, so if someone could help that would be great.
Cheers
