Hey everyone in the know,
For some strange reason my Bios decided to change the boot order of my hard-drives so when it rebooted I got the 'Disk Error, please insert the system disk' error.
Basically the comp froze whilst playing GTA 4, it wasnt responding to anything so I did a cold restart with the reset button, thats when I was presented with that message. Cursing and swearing I thought my comp had lost its volume label for the partition (is that what its called? Ive had it in the past, when it refuses to boot into Windows until you reinstall?)
Anyway, used the XP CD to repair the XP install but XP didnt show up in the list of already installed operating systems, keeping the formatting structure intact I did a new install. Restarted and got the Disk Error again, cursing and swearing again I checked Bios where I found my HDD Boot priority had been changed!!!! Ive never changed it since I built the machine 6 months ago! Anyway, with the correct priority it seems I have installed XP twice on the same drive. Folders 'Windows' and 'Windows.0' and I get the OS choice list on bootup, sorry for babling on, that brings us to the question...
How can I safely (without messing anything up) delete the new install of Windows XP and keep the old one intact and not run into any errors?
What needs to be deleted or changed in addition to the following?...
* Delete Windows.0 folder
* Edit the startup file to stop the OS choice menu showing
Anything else?
Thanks for the help in advance peeps, and merry crimbo!
M.
Anything else?
M.
