RJC said:what are your temperatures like in the BIOS for CPU and and system.
Rob
cpu temp 23
sys temp 44
is that normal? the sys temp was rising by 1 every 30 seconds or so (it was on 38)
Rob
scottyboy said:cpu temp 23
sys temp 44
I disconnected the Zalman fan controller and now there is no beeps!ih8modem said:Is it not perhaps the zalman fan controller beeping? I have a Coolermaster cool drive 4, and one of the fan is set low. this triggers a continous alarm until you actually acknowledge the alarm by selecting the fan, then pressing the big silver knob.
See if there is something similar on yours - just a suggestion as everything else seems to have been suggested/tried/checked already.
When you have everything in place, the unit immediately lights up and allows you to change the speed of the attached fans. If you don’t have a fan on a certain channel or if the fan isn’t turning/working then the unit will start beeping at you loudly until you sort the problem out, or disable that channel by pressing ‘mode’ until the right channel is selected and pressing in the jog wheel.
scottyboy said:thanks it was!
swede this might help u..
it worked for me.
