Help! just upgraded to a Galaxy S2 and am lost
1 Apr 2003
London
Morning,
Upgrade time for me and switched from a Blackberry 9780 to a Samsung Galaxy S2. Feels like a big upgrade but I am completely lost with it and android.
Its packed full of preinstalled stuff at the moment, is it possible to do a complete format and start over? Where do I get the latest version of the operating system from?
Very confused at the moment! Thanks
Set up your 7 homescreens as you wish, i recommend trying a few widgets. Have a look in the android app thread on here, ive had a read through it and found some great apps. Set up your wifi, and basically just play around with the phone and you'll soon get the hang of it. Don't give up - once you know your way around using the phone is effortless and nothing takes more than a couple clicks. Enjoy
I don't believe it's possible to format it without a custom recovery or rooting, so I'd leave that for now.
It should already have the latest version of Android, 2.3.4 or 2.3.5.
Find Appbrain in the market, create an account, then take a look at www.appbrain.com
I find it much easier to filter and find the better apps :)
