I'm pulling my hair out
I've just re-wired my house with Virgin Modem linked to a Asus RT-N56U Router in the lounge.
I have a NAS pluged via 1m cat5e in to port 1 and two Bedroom PC's via 15m cat5e in ports 2 and 3. NAS, Router and both PC's have gigabit ports. Port 4 as a switch on it and is distributed between consoles and media players.
Cables being used are all brand new and I have carefully routed the cables to bedrooms under floorboards etc. (took all day)
The problem I have is both bedroom cables are only working at 100mbps instead of 1000mbps(gigabit). After much testing I've come to the conclusion that both 15m cables are ****!
With the aid of a switch and 2 x 5m cat5e cables I managed to link a bedroom PC down to the router by trailing the cables round the house and got a gigabit connection. So must be the cables (am I right?)
Is there anything I can do with the existing cables so as I don't have to go ripping floor boards back up? If I do have to buy new cables will buying cat6 cables be a safer bet and will they work with the rest of my cat5e network?
