Hi OCUK!
Hope you're all feeling merry!
For some reason the display on my laptop is glowing (the back light is lit), but it is not showing anything, not even the system info at the start up.
Now luckily i plugged a second monitor in and the second monitor displayed what should have been on the laptop display.
But recently that has failed.
So i get no display on my laptop screen, nor on an external monitor.
Any idea what it could be?
Laptop -
Rock Xtreme CTX t2700
# Intel Core Duo T2700 2.33GHz
# NVIDIA GeForce 7900 Go GTX 512MB
# 2GB DDR2 667MHz
# 100GB 7200rpm SATA
HOPE you can help!
Laptop -
# 2GB DDR2 667MHz
HOPE you can help!
