Help list 1228 pdf's !
30 Aug 2003
Straya
I currently have 1228 pdf's on my local drive, that I need to list out on a spreadsheet, including the file extentions i.e.: example.pdf , example2.pdf etc.
I know there is a Dos command to do it, that will list it out in a .txt file, but I keep forgetting how to do it.
Do you know how to do it, or know of a simpler way to do it with windows, or in fact an application (i suck with dos)
cheers
Yeap, they are in the same folder.
dir "b" <-- that b being my directory i have it in (I'm complete dos noob ... try keep it in mind ;) )
oh, say they're in C:\docs\
start, run, cmd
c: press enter
cd c:\docs press enter
dir /b > files.txt press enter
now go to explorer and c:\docs, the files.txt file will be in there..
if you type "dir /?" it tells you the options, the /b is for removing extra file information -strips the info from the text file
-edit, or just save this file and place it in any directory you want to list the files for and double click it once :)
http://bleddyn.co.uk/temp/supercow.bat
-folders will be named too, but without extention
start, run, cmd
c: press enter
Cheers mate, that worked a treat :)
