- 9 Aug 2020
.SPE seems to be a somewhat obscure video/image format - not sure if it has an audio track. Another (probably more likely) possibility it is actually Speex data.
Could try opening it with 7-zip - sometimes it is just a self-extracting container - you don't really want to mess about with an exe from an unknown source. One of the codec packages with Media Player Classic or similar like k-lite and the right codec package might be able to play the original file once decrypted.
Letter says to try DSP group true speech... Does anyone know of any software?
Thanks for that. The file name all ready seemed to have .exe at the end.
https://www.amazon.co.uk/photos/share/d4HNZATqc6lGWwnYju94csabMoNsF2aH6mtTRVTAOFZ
This DSP truespeech seemed to be built into xp and vista but not currently - I think from reading.
I will try your second option, probably the worst file choice they could send and instructions!
Nightmare!
It's working now!!!! Thanks so much!
