Help locating correct transformer for Ring Pro Doorbell
2 Aug 2021
UK
Hi there
I have a Ring Pro Hardwired doorbell, and am having a devil of a job sourcing an appropriate transformer for it.
It needs 16-24V, 20VA to work properly.
Please can anyone point me to where I can get a DIN rail transformer that I can use for the install, as I'm going around in circles, and Ring themselves have none in stock anywhere in the world.
I don't want to use the adapter in the box (which delivers 24V / 500mA DC), as I don't want wires trailing unnecessarily.
(oh and to note, I tried installing a 24v / 500mA DC transformer as part of the hard wire install. Things worked perfectly for a few hours, and then the doorbell malfunctioned. As part of troubleshooting with Ring, they are shipping a new product but told me that the only set up they support is using an AC transformer, and a power pro pack, and that the DC install that I have tried may damage the unit (though I cannot understand why, and they could not tell me)....
Thank you!
****UPDATE****
Having checked the transformer that Ring themselves ship, it's a DC transformer! DIN Rail Transformer for Wired Video Doorbells – Ring
So I think I am correct in thinking that the 2 people at Ring that I was speaking to actually have no idea what they are actually talking about, and the set up that I have implemented should work fine....
Any thoughts gratefully received....
Thanks Noobcannon.
But this isn’t correct - power output is far too low.
As stated, it needs 20VA to work.
It defiantly doesn't. If im doing my maths correctly the transformer i linked is 8/24 = 0.33amp 8w close enough imo.
The 3 pin adapter/transformer supplied is 24v / 500mA DC. Which is why i am so confused. They are adamant I need a 16 volts AC at ~20 volt-amps transformer.
I installed a transformer by my consumer unit that is 24v / 500mA DC, but Ring are saying this isn't correct and i need an AC transformer plus the separate power pack which i think converts from AC to DC). But they can't tell me why and I am losing faith that they have any idea what they are talking about!
