help, looking for a wireless card
7 Nov 2009
hey guys, i have changed from ethernet broadband to wireless because i have changed computer location and the ethernet wont stretch.
anyway, I was told I could use any old PCIe/USB wireless adapter but I would be best getting an N grade PCIe card as this would give me best speed results.
can someone spec me one of these please? I would be very grateful :)
i like the USB ones as
1) you dont want the signal having to go thru the case to get to the arieal
2) you can place it for best reception
I ahve been using the Edimax WLAN nLite High Gain USB Adapter's recently they have a nice big aireal on... dunno if the big aireal helps but i makes me think it will... they are only £13
