help make my mind up
9 Dec 2012
newcastle upon tyne
hi i few days ago i put a post up asking about why 7870 to get and was about to order my card and i seen this on sale so i thougth id ask if you guys would reccomend me what 1 to go with the 2 cards are
http://www.overclockers.co.uk/showproduct.php?prodid=GX-049-HS&tool=3
http://www.overclockers.co.uk/showproduct.php?prodid=GX-312-SP&groupid=701&catid=56&subcat=411
my system is
intel core i5 3570k
mob https://www.overclockers.co.uk/showproduct.php?prodid=MB-555-AS
8gb of Patriot Intel Extreme Masters ram
Seagate Barracuda 7200.12 500GB hardrive
Cooler Master GX 550W '80 Plus Bronze' Power Supply
case https://www.overclockers.co.uk/showproduct.php?prodid=CA-018-XG
This one's on offer this week ...
http://www.overclockers.co.uk/showproduct.php?prodid=GX-065-HS&groupid=701&catid=56&subcat=1673
It's clocked higher than the reference card and it's cooler is very effective and very quiet. It eats games up at 1920x1080 and stays cool while you're playing, I've never seen above 61C on mine and that was while playing Far Cry 3. At idle it is all but silent and when it's pushed hard its still one of the quietest 7900 series cards out there.
The 7950 is the faster card clock for clock but it has a noisier reference cooler. The 7870 xt is a bit slower but has a none reference cooler which should be quieter. There is also this which uses the same gpu as the sapphire but a different cooler. http://www.overclockers.co.uk/showproduct.php?prodid=GX-013-VX&groupid=701&catid=56 . Also the links for your mobo and case don't work.
would u say to get that card over the 7870xt
