Hi guys. My experience of phone/network cabling is restricted to installing a phone extension - nothing to complex.
Me and the partner have just moved house and we're having a bit of a nightmare getting the wiring right for our infinity connection.
The master socket is in the hallway (no power outlets) - there's no extension into the living room.
The previous occupiers removed an extension into the living room as it stopped working - I tried to sort it but it just won't work so I expect there is an issue with the extension wiring points in the master socket.
The existing master socket is a single telephone point openreach socket typical of an ADSL install.
BT have suggested that in order to get infinity working we need a new phone/Vdsl master socket and that the router must connect into this - not via any extensions - leaving us with a huge cable exposed from the hallway to the router.
- A friend suggests buying one of these master sockets , placing it in the living room, and connecting it to the existing master via gel crimps on the A/B connections.
Isn't there a better way ? BT want £140 to even look at the master socket as it works for everything except extension wiring.
What should I do? Thanks
