Help me a choose a gpu for my build please
7 Sep 2013
Mobo: ASrock z77 oc formula
CPU: i5 3570k
Cooler: akasa voodoo venom multi fan (extremely large)
Plus 7 fans
Case: full tower nzxt phantom enthusiast
Ram: corsair 16gb vengeance
Psu: cooler master m2 1000w
The gpu I'm looking for is something that will play bf3 on ultra and other games fine, ranging from £150- £250 maybe push a little more but rather not, I'm using a 22inch monitor hd.
I have a gpu in mind which is the Gigabyte ATI Radeon HD 7870 OC Windforce 3X 2048MB GDDR5 PCI-Express Graphics Card from overclockers
Any advice on any of my planned system I would appreciate but it's mainly the gpu I'm unsure of
Not worth the price difference over the IceQ that arc@css linked and Sapphire have pretty dire RMA feedback.
You can't link to competitor sites here mate. I'd remove that link :)
Thanks but I think I've decided on the slightly more expensive sapphire series what do you reckon ? It works out around £250
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202001
I would remove competitor links!
Sapphires are prone to coil whines and the RMA process is long as they are located in Hungary. I'd recommend a HIS or Gigabyte.
Depending on your location, you can get a 7970 for about the same price.
YOUR BASKET
1 x MSI HD 7970 Twin FrozR OC BE 3072MB GDDR5 PCI-Express Graphics Card with FREE GAMES £269.99
1 x HIS HD 7970 3072MB GDDR5 PCI-Express Graphics Card (H797F3G2M) £249.95
1 x HIS HD 7950 IceQ BOOST 3072MB GDDR5 PCI-Express Graphics Card (H795QC3G2M) **Voltage Unlocked** £187.99
Total : £719.93 (includes shipping : £10.00).
I've removed the links thanks for that sorry, I thought about a gigabyte one initially I've found a sapphire one at 207 pound think its the model below the one I first mentioned Sapphire 11196-09-40G HD7950 3GB Vapox-X Graphics Card, ill take a look at what you suggested though thanks for your help
