- 27 Apr 2004
- In bed with your sister
I am considering building a benching rig and would like some advice please.
The plan at the moment is to use a Vapochill lightspeed unit to cool the CPU and have dual watercooled gfx cards.
I have a DFI expert motherboard on one of my rigs just now and like it very much but I like ATI gfx cards. My question is, would the DFI crossfire board clock as well as the expert so I can go crossfire with 2 X1900s or would I be better with the expert board with 2 7900s in SLI?
Also, being a bit of a watercooling noob, I would like some advice on which components would be best for the gfx cards and Northbridge. I would prefer blocks which cover the ram chips as well as the GPU. Which pump, rad/fans, reservoir, blocks would be best?
Which PSU would be best for this rig? I need something which will give me adequate power and stability for benching at high clocks.
Also need advice on RAM. Which RAM would be best for this sort of job? I would imagine I would be better with RAM that can run with tight timings on a divider rather than high bandwidth (I will be using this particular rig for AMD chips with the possibility of making up a seperate mobo/RAM set up for Intel when the Conroe chips and boards come out).
I was intending mounting it on a table for easier access when changing stuff out and to help cooling, I was also going to point a deskfan at it to help keep the whole lot cool whilst in use. When not in use I will be covering the set up to keep out dust etc.
I will be using a 37Gb Raptor for storage and installing a trimmed down version of Windows (using nlite) and only installing benching software etc. Any advice on benching software etc.? or would I be better asking in the Overclocking forum?
Please only suggest items stocked by OcUK as I prefer to buy my stuff here (I have seen the lightspeed unit a fair bit cheaper elsewhere but I like dealing with these guys and can't be bothered ordering stuff from here, there and everywhere).
Don't be afraid to suggest pricey items as I would rather spend a few bob and get a really good system than compromise and have a good system at a reasonable price
Stan
Stan
and all he wants it for is benchmarking
