Help me build a budget gaming rig.
10 Aug 2005
Hi people
I have a max budget of £450 to buy a tower used mainly for gaming and video editing.
Only using a resolution of 720p so not too graphically intensive.
Need case, cpu, board, ram, hdd, gpu only.
Would like to run modern games full eye candy if possible.
Any help appreciated.
A Budget AMD build with SSD?
CPU is an AMD APU and gaming ready out of the box, it does alright in games (DX11) maybe a bit of let down in the video encoding dept tho.....
YOUR BASKET
1 x AMD A10-5800K Black Edition 3.80GHz (Socket FM2) APU Trinity Quad Core Processor **FREE SIMCITY PC GAME** (AD580KWOHJBOX) £91.99
1 x Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) £83.99
1 x Gigabyte F2A85X-D3H AMD A85X Chipset (Socket FM2) DDR3 ATX Motherboard £64.99
1 x Corsair Vengeance RED 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (CMZ8GX3M2A2133C11R) £59.99
1 x Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) HDD £47.99
1 x Corsair Builder Series CX 430w Modular '80 Plus Bronze' Power Supply (CP-9020058-UK) £39.98
1 x NZXT Source 210 Elite Midi Tower Case - White £36.98
Total : £440.02 (includes shipping : £11.75).
Or an Intel (over budget I know but this socket will be dead in a few weeks), but it does offer much better performance overall.
YOUR BASKET
1 x MSI HD 7850 OC 2048MB GDDR5 PCI-Express Graphics Cards £149.99
1 x Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £89.99
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £49.99
1 x Gigabyte H61MA-D3V Intel H61 (Socket 1155) DDR3 Motherboard £47.99
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
Total : £473.02 (includes shipping : £11.75).
I'd put the largest part of that budget into the GPU... It doesn't matter what motherboard you get for a gaming rig as a £50 board is likely to perform similar to a £200 board at stock clocks (you won't notice any real world difference)... You obviously won't have as many features or OC capabilities, not that i'd recommend OC'ing with a budget board anyway. You'd be better off going for the cheapest 'value' type RAM you can find too, although faster RAM would be preferable if using an integrated GPU.
Forgot you needed a hdd.
If you decide to get the Foxconn mobo, you need to ask OCUK to update the bios for the IB Cpu. Unless you have a SB cpu you can use to update the bios yourself.
YOUR BASKET
1 x **B Grade** Gigabyte ATI Radeon HD 7850 OC Windforce 2X 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz, Sleeping Dogs & Dirt Showd (GX-100-GI) £129.95
1 x Intel Core i3-3220 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £92.99
1 x **B Grade** Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (S (HD-257-SE) £45
1 x Corsair Builder Series CX 430W V2 '80 Plus Bronze' Power Supply (CP-9020046-UK) £40.99
1 x Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP4G3D1609DS1S00CEU) £39.95
1 x Foxconn H67M Intel H67 (Socket 1155) DDR3 Micro ATX Motherboard £34.99
1 x Samsung SH-224DB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM £17.99
Total : £449.84 (includes shipping : £12.50).
Memory on today only special price.
