Right, first off, here is the layout of my room where I want the desk:
The desk has a 50" plasma on it, what I want to do, is rid of that desk, and buy a 'worktop' that will span from wall to wall. Note though, that little box in the right corner, it has our gas meter in it, so I cant simply have a work surface with 4 corner legs... But in order to squeeze my 24" monitor by the side of my plasma, I need to have a desk from wall to wall...
What are my options, I can't fix anything more than a few KG to the walls as they are plasterboard...
What sort of material should I go for for the desk and what should I make the legs out of? Due to it needing to hold in excess of 45kg's of weight.
Any help would be much appreciated!
ags
ags
