Hi,
I currently have a small ZBOX ION2 HTPC where I can surf the web and watch hd movies pretty easily. However I have started to like the idea of sitting in the living room and gaming on the big 46"TV as well.
I am thinking of building a HTPC which can also play games at 1080p.
Would the latest trinity apus be enough or should I go for an Intel+dedicated GPU? And if I need a dedicated GPU, which one would you recommend noise and power wise?
For the dedicated CPU/GPU route, I think I3 and matx Z77 with 4GB will be enough.
Thank you in advance
