Seeing 80C on my Xigmatek DarkKnight, while OCing my DC to 4,7 makes me consider water. I don't want the AIO, which are middle road, but would like to go straight loop.
So far, due to money restriction, I'm building CPU only, then in few months (and after I see if new gtx 800 beats 780 ti
) I'll add gpu to loop too.
I've chosen following parts:
360 Nemesis Xflow with corsairs PWM 120SP fans in front of my Carbide 540
280 Xflow on top (for GPU), unless you can cool GPU and CPU with 360
EK Supremacy Nickel CPU block
EK fittings
Primochill SRT clear tubes with Mayhems sunset yellow pastel
And now the pump... will the DCP 4.0 be enough for GPU/CPU and possible 2 rads, or should I go D5?
) I'll add gpu to loop too. I've chosen following parts:
EK fittings
