Hey all, I made a post in the upgrade help section but it got lost under the weight of other spec me threads so figured I might have more joy here
as per the title I’m after some advice as to what to replace my 5820k with
I’m well out of touch and with all the options in terms of cpu choice a little lost
From reading some of the threads on here it seems best bang for buck choice is a toss up between
7600X, 13600k & 5800x3d
It’s only going to be used for gaming @ 3440 x 1400
current set up is as follows
5820k @ 4.5ghz
16gb @2400mhz
Msi x99 krait mobo
Powercolor 6800XT red dragon
Corsair 850rmx
It all also be going in a custom loop in terms of cooling
Any advice on something that will give me a good few years of decent performance would be appreciated
Thanks
Fritzo
5820k @ 4.5ghz
16gb @2400mhz
Msi x99 krait mobo
Corsair 850rmx
Thanks
Fritzo
