Help me choose a gpu for my new rig
At this point, I would suggest either a gtx480 or a 6950. The slight performance premium on both the 6970 and gtx570 do not justify the extra cost. If you are going for FsX, I would suggest a gtx480. for everything else, I would suggest a 6950 unlocked.
The gtx560 was instrumental in bringing the prices of AMD's cards down, but that has left it in somewhat murky waters itself. I wouldn't buy one as of this moment, unless the price is lowered another £15-20, as it is not as fast as a 6950 at stock or overclocked and only has 1gb of ram in it
*edit* on the subject of unlocking a 6950, it is safer to unlock the shaders than to flash the bios to a 6970, as the 6970's ram runs with different timings, as well as running a higher vcore. The issues that Tute found I'm guessing were people flashing the card.
I agree with you when you say that the 570 and 6970 aren't really worth the extra. They don't have much of a performance increase for the £. For a heavy o'c though a 570 would be a star im guessing. After reading around, only unlocking the shaders would give me a 1-2% increase. Given the lack of risk due to the double bios switch, I'd most likely take the chance with the flash. Besides, overclockers are now advertising the rev 1 asus 6950 as 'flashable to a 6970'. I'll just make sure I have good airflow in my case and don't overclock any further. Then i'd put another in xfire :D
Does the 2gb of ram on the radeons not help in fsx no? Kind of thought that it would
to be fair mate, I don't know a massive amount about the technical tendencies of flight simulator beyond the fact that it prefers Nvidia cards. The 6950/70 come with 2gb, the 480 with 1.5gb. I would have thought Flight sim would run nicely on both really, as if it was that Vram hungry it wouldn't give it much of a market!
