Toying with the idea of upgrading my psu in readyness for going sli. I have a build to do for a freind and can pass him one of my psu's cheap to cover part of the cost. Currently using a antec high current gamer 620 watt.
pc spec is
3930k
16gb
gx670
single ssd and two 1tb hd's
xspc 750 water cooling kit.
when overclocking i've seen it use as much as 480watts at the wall under full load, and thats without loading the gpu. What i'm looking for is a modular power supply, no specific budget but preferably around £150 willing to go more if required, dont want to spend more than i have to, but want to get the right thing. Capable of running the 3930k at 4.6-4.8ghz and two gtx 670's in sli. I have about 7 fans and will probably be adding more drives and memory in future if it makes any difference. Thanks in advance.
pc spec is
3930k
16gb
gx670
