- 17 Aug 2007
- London, Moscow & Samara
i use 3/8 barbs and tubing never had a problem. The tubing sits on tightly to the barbs. So tight infact i do not require clips.
Bikerz said:They all on low mate and system lovley and cool but still too loud. CPU never got above 46 degreees yet even when gaming
How do fan controllers work? What fan input will they accet? the white 4 pin conectors or will they take the larger 4 pin ones that you get to power IDE dvd drives etc... as they are the connections on my fans at the min. Can someone take a pic of the back of there fan control unit so I can see please?
Cheers
Sheldon
