Hi guys,
I'm building a new hard-tube watercooled system inside a Phanteks Enthoo Primo case. I currently have a Rampage VII motherboard (DDR3) with an i7 4790K but wanted to upgrade all this when I move into the new case, and move to DDR4
I think I am settled on the CPU (i7-5820K 2011-V3) and the RAM Corsair Vengeance LED DDR4 (16GB). The motherboard is where I am stuck. I don't want to spend loads, so around the £200 mark is where I am looking. I think I have narrowed-it down to 4 possibilities:
1. Gigabyte X99 SLI
2. Asus X99-E
3. MSI X99S Plus
4. Asus X99-A II
I am guessing the first two must be good, and OCUK use them in their pre-OC'd bundles. The last one is expensive, but if it's significantly better than the other options, then I may consider it.
Does anyone have any advice/experience with these? I've read lots of reviews, but some 1st hand feedback would be great!!
Thanks! Ori
1. Gigabyte X99 SLI
2. Asus X99-E
3. MSI X99S Plus
4. Asus X99-A II
Thanks! Ori
