- 12 Jan 2006
Ok i cant choose between them any advice is very much recommended, i have £500 to spend and have narrowed it down to the following because i really want to make sure it has dedicated graphics to play some lower end games (highest spec probably CSS/Battlefield 2 ish sort of thing)
So i am down to
Dell Studio 15
Intel® Core™ 2 Duo Processor T5550 (1.83 GHz, 667 MHz FSB, 2 MB L2 Cache)
Genuine Windows Vista® Home Premium SP1- English
15.4" Wide Screen WXGA (1280 x 800) Display with TrueLife™
256MB ATI Mobility RADEON HD 3450
3072MB 667MHz Dual Channel DDR2 SDRAM [1x2048+1x1024]
250GB (5400RPM) SATA Hard Drive
Fixed Internal 8X DVD+/-RW Slot Load Drive including Software
for £499
or
Toshiba Satellite A200-244
# rocessor - Intel Core 2 Duo T5450 / 1.66 GHz ( Dual-Core )
# RAM - 2 GB (installed) / 4 GB (max) - DDR II SDRAM - 667 MHz ( 2 x 1 GB )
# Hard Drive - 200 GB - Serial ATA-150 - 5400 rpm
# Operating System - Microsoft Windows Vista Home Premium
# Screen - 15.4" TFT 1280 x 800 ( WXGA ) - 24-bit (16.7 million colours) - TruBrite
# Optical Drive - DVD�RW (�R DL) / DVD-RAM
# Graphics - ATI Mobility Radeon HD 2400 - 128 MB dedicated, HyperMemory up to 895MB <- not sure what that means, shared ram?
£399.97
Now i was going to buy the upgrade to 4 gb of ram which will bring it to £494.97
I am looking for a good solid laptop which is why i went for known brands, but other suggestions are welcomed
Thanks in advance
So i am down to
Dell Studio 15
for £499
or
£399.97
Thanks in advance
