Hi all, I am now back with my ideal choices of headsets to choose from but I need some help for my final decision!
The sound card and headsets I chose bellow are 100% for gaming.
First of all in terms of Sound card I chose this: http://www.overclockers.co.uk/showproduct.php?prodid=SC-017-AS
Hopefully that passes the approval
This morning I was extremely close to buying the Razer Tiamat 7.1 but my mate is bugging me to seriously consider the Sennheiser G4ME One's.
Like I said they are both purely for gaming and what one will you guys choose from? And hopefully that sound card goes well together with the headsets.
I found the Tiamat's £50 cheaper than the Sennheiser's some where else but not considering the price difference what will be the clear winner or if you guys can recommend a better headset for best bang for buck I will appreciate that
Thanks!
Thanks!
