Help me choose fans for my new rig in a P180!
16 Jul 2004
So, I've just put a new rig together (i7-2600K based) in my old Antec P180 using a Noctua NH-D14 cooler. My requirements are for generally silent or close-to-silent cooling on idle/low loads, with a ramping-up when the temperatures require it.
I have 6 fan areas, let's call them:
A1 CPU fan 1
A2 CPU fan 2
B Rear case
C Top case
D Front case
E Bottom case
(the image is not of my PC)
I have an Asus P8Z68-V motherboard with three duty manageable fan headers:
CPU_FAN 4-pin header based on CPU temperature
CHA_FAN1 4-pin header based on motherboard temperature
CHA_FAN2 3-pin header based on motherboard temperature
The Noctua NF-P12 (A2) and NF-P14 (A1) on the cooler have 3-pin headers, therefore these cannot be duty managed by my motherboard based on the CPU temp. I am going to keep the NF-P14 central fan with it always on low mode - 10.1 dB(A) - and replace the NF-P12 with a 4-pin PWM fan. Requirement 1.
The bottom case fan exists to cool the hard drives. My Seasonic X-760 will not run the fan below 150W draw (which isn't drawn at idle), and as there's no/very little movement of air between the top and bottom sections of the case, it gets kinda stuffy down there and my hard drives seem to roast. I want an always-on fan that exceeds 39 CFM and does not exceed 25 dB(A) of any connector type (basically better than my current ageing/dying Antec Tri-cools on "Low" when new). Requirement 2.
The front case fan exists as the primary intake fan. Creating a vacuum in the case will draw air in, but I like to have some driven intake to help airflow. This fan should be always-on, and can be of the same type as the bottom case fan. Requirement 2 again.
The top and rear case fans are there to help with the CPU area. The rear case fan is in-line with the Noctua NH-D14 air direction and so offers a more complete extraction of the warmed air. The top case fan is essentially just an extra fan to improve the natural movement of warm air from the top of the case. I would like these to be the power managed case fans. I will set these at a temperature that I will test to be around where the motherboard temperature is representative of a prolonged high CPU load that has caused the ambient case temperature to rise. I need 1 4-pin and 1 3-pin. Requirements 3 and 4.
Requirement 1: A2 - 4-pin PWM fan with dB(A) <= 12.6 dB(A) and CFM >= 37 on 20% load, and a good ratio of SPL/CFM from on higher loads.
Requirement 2: D and E - 2x any connector fans with dB(A) <= 25 and CFM >= 39.
Requirement 3: B - 4-pin PWM fan with dB(A) <= 25 and CFM >= 39 on 40% load, and a good ratio of SPL/CFM from on higher loads.
Requirement 4: C - 3-pin fan with dB(A) <= 25 and CFM >= 39 on 40% load, and a good ratio of SPL/CFM from on higher loads.
As I am replacing the Noctua PF-12 on the cooler I have a spare 3-pin fan with 54CFM and 19.8 dB(A) at 100%, and 12.6 dB(A) and 37 CFM at 40%. This meets requirements 2 and 4. As 4 is the tougher requirement, I'll say I'll use it for 4. I am therefore left with needing to meet Requirements 1, 2 and 3.
In simpler terms, I'd like 2 4-pin PWM fans that are very quiet on lighter loads, but ramp-up nicely to a good SPL/CFM ratio on higher loads, ideally up to around 60 CFM at 100%. I'd also like 2 fans of any connector that can sit with dB(A) <= 25 and CFM >= 39.
Any help would be greatly appreciated! Cost is not of a major concern as long as we aren't talking £20+ a fan. All fans are 120mm.
I hope you are aware that most fan manufacturers talk out of their rear with regards to noise and CFM. The only fan specs I would even remotely trust would be from Sanyo Denki, Nidec Servo Corp and our old friends from Delta.
I thought you could fit a front fan in the lower chamber on the P180 so you can have push-pull airflow over the HDDs. :confused:
These seem to fit the bill with the modular connectors although they are out of stock.
Akasa Apache Blacks seem to be quite popular for both case and heatsink.
My personal favourite fan would have to be the Gentle Typhoon's, either in the 1850 RPM or quieter 1450 RPM versions. Many other speeds are sold, but OcUK do not stock these. These are ran off a Molex connection with a 3-pin tach wire though as common with many other high quality/high power fans.
Yup, but it's all we really have to go on. It's difficult to find any singular testing methodology that has tested a wide enough range of current fans to use it for benchmarking. I've found the various reviews from X-Bit, silentpcreview et al and I am verifying the manufacturer claims to be 'reasonable' when I think I've stumbled on a fan that works.
The P180 can take a fan there, but I'm not too concerned about having a significant amount of airflow around there; just enough to keep some kind of movement going. I may go for a push in the opposite direction (so taking from the front exterior over the HDDs) to avoid just blowing warmed PSU air over the HDDs.
I am glad you chose the Silent Eagle SE - I'd seen them and they are on my mental shortlist. The Akasa also seems interesting. I'll try to find comparative reviews of them both as I think one of these two may win it. The modular connectors of the Silent Eagle SE are also interesting, as I can 'control' the always-on fans to a noise/airflow level that suits me.
Regarding the Typhoons, I could get 1 as they are 3-pin (my motherboard can duty control 1 3-pin fan... weird), but I really want duty control on the CPU fan. Thanks!
Looking at the specs, I think the Akasa AK-FN059 Viper will work for the CPU fan - it appears to match the AK-FN058 but with a higher maximum RPM and thus airflow. The CPU fan can be duty managed down to 20%, so this should be very quiet at those speeds of ~400 RPM.
For the the chassis fans that can only be duty cycled to 40%, I like the Akasa AK-FN058 Apache. This can be duty managed down to ~500 RPM and appears to have a good noise/airflow ratio at higher speeds.
For the two fans that are always-on, I think the Sharkoon Silent Eagle SE works the best, mostly because it comes with in-line resistors that mean I can choose what mode to leave them on. This will probably be a relatively quiet mode.
So, we have:
A1 CPU fan 1 Noctua NF-P14
A2 CPU fan 2 Akasa AK-FN059 Viper
B Rear case Akasa AK-FN058 Apache
C Top case Akasa AK-FN058 Apache
D Front case Sharkoon Silent Eagle SE
E Bottom case Sharkoon Silent Eagle SE
Seems OK? Any possible improvements?
EDIT: The discovery of the Akasa AK-CB002 has changed everything.
I have bought:
1x Akasa AK-FN059 Viper
3x Akasa AK-FN057 Apache
1x Akasa AK-CB002 3-way 4-pin PWM header splitter
Arrangement will be:
A2 CPU fan 2 Akasa AK-FN059 Viper, PWM by CPU temp
B Rear case Akasa AK-FN058 Apache, PWM by ambient temp
C Top case Akasa AK-FN058 Apache, PWM by ambient temp
D Front case Akasa AK-FN058 Apache, PWM by ambient temp
E Bottom case Noctua NF-P12, always-on with ultra-low-noise-adapter
This way I have the CPU fan running normally at 400 RPM able to ramp to 1900 RPM (in addition to a Noctua NF-P14 doing light duty all the time), the case fans at 500 RPM able to ramp to 1300 RPM, and just some basic airflow in the form of the NF-P12 to keep the hard drives from roasting.
Seems ideal! Thanks for the Akasa ref Vinni :)
The Apache is the first "expensive" fan I have bought and am really happy with it, and I am a bit of a noise freak.
