I fancy trying a mechanical keyboard for general use at work.
Can you suggest some good, but not too pricey ones?
I know there are quite a few listed here, but from browsing around there seem to be various ‘other’ brands that might suit.
Think an ‘80%’ one would be good. No need for number pad, but I do need F keys.
I’ve also found some nice Tai Hao keycaps that I want, so need one that I can add them too.
Also like the idea of the coily USB cables
Afraid this may all sound very newbie
On another note, it also seems you can build ones from the ground up?
Not quite at that point yet, but how would I start?
