Help me choose next 2 hours
4 Aug 2014
I have no monitor and having withdrawal symptoms not using my beloved gaming rig. And
I want to get either Asus PG278Q ROG Swift or Samsung 32D850D or something as good and i'll eventually get 3 of whatever i pick.
The 2 hour limit so i can get it tomorrow if order before 4
Guess it depends what GPU's you have. Nividia I guess with the want for the ROG swift. Running 3x 1440p will need some monster GPU HP so I guess the ROG will benefit from G-sync at the lower frame rates. As you upgrade GPU's then you'll be able to take advantage of the 144hz refresh too.
