HELP!!!! Me choose which cpu and is my psu ok
19 Aug 2012
hi guys im just looking for some guidance i am going to make a purchase tonight or tomorrow and i am not sure what to do atm i have a a8 5600k with a crappy a55 mobo i have an asus hd7850 graphics card and a corsair 600 cx power supply my case is a zalaman z11 with 5 fans not including the cpu coolermaster evo 212 what i am looking to find out is i am going to purchase
Gigabyte 970A-DS3P (Socket AM3+) DDR3 Motherboard
with 8gb ram
but my main query is should i go for an fx 6300 or an fx8320 i only play world of warcraft and a little dayz but mostly wow
i am also wondering is my psu enough to handle this
Thanks chris
Your 600W PSU should be plenty for this build. Try entering your details into a calculator like this if you want an estimate of whats required: http://powersupplycalculator.net/
The fx6300 is a reasonable CPU and is better value for money than the fx8320. But then the fx8320 would last you a little longer and is a fair chunk more powerful. Up to you really - it's a question of value vs performance/longevity.
Personally, I'd probably go for the more powerful CPU as I don't like to upgrade very often.
