i need some help with advice by ppl who have maybe seen these monitors in person and have experience using them but if u don't then any advice will be greatfull
i will use the monitors for web browsing / gaming pc / movies / xbox360
the 3 monitors on my short list are:
Asus VH222H 22" Widescreen 5ms response time
http://www.overclockers.co.uk/showproduct.php?prodid=MO-014-AS&groupid=17&catid=949&subcat=
Iiyama ProLite B2409HDS 24" Widescreen 2ms response time
http://www.overclockers.co.uk/showproduct.php?prodid=MO-047-IY&groupid=17&catid=510&subcat=
and finally since its the same price as the above Iiyama i would like to know abit more about the Samsung SM2494HS 23.6" Widescreen since it doesn't show on samsung website but the HM version does is there much difference?
Samsung SM2494HS 23.6" Widescreen 5ms response time
http://www.overclockers.co.uk/showproduct.php?prodid=MO-107-SA&groupid=17&catid=510&subcat=
