- 20 Oct 2005
Right first things first. I have been using Pentax for the last 5 years but now feel the need tp upgrade
Options I am considering are
1. Sell my Pentax gear and help fund an upgrade to either Canon or Nikon.
2. Upgrade my K10d to a K5 and buy a new 55-300 lens Cost £1000ish
Looking at Canon I have put a 60D as my choice of body along with EF 70-300 f4-5.6 IS USM lens Cost £1200 ish - but then need some lenses to fill the gaps. Are there other bodies I should be considering? Is this lens a good choice?
Nikon throws up a few options
Push the boat out and buy a D300s and this is where it get difficult as there are 3 choices for xx-300. 55-300 ED VR @£290, 70-300 IF ED @ £430 and 28-300 G ED VR @ £700. Have no clue which lens is best for IQ or focusing etc so this is where I need help. Cost up to £1700 depending on lens.
Cheaper option then a D90 with 18-105 VR for £700 plus then what ever lens from the selection above Cost up to £1400.
SO there you go any advice greatly received.
Should add the 300m lens will be for aircraft (static and Flying)as well as zoo use etc.
