Hi guys, I've more or less decided on the case to build my new PC up from, the Fractal R4. My aims are to have a powerful gaming PC that can also be fairly quiet and unintrusive to look at.
My budget is £800/900 I've already got a Monitor, Keyboard, Mouse, Windows 7.
My current Rig is as follows.
AMD FX-4100
8GB Kingston Hyper X DDR3
M5A78L Asus Mobo
GTX570 PNY
128GB Kingston SSD
Asus DX2 Sound
3 Storage HDD
Corsair CX 600W Non Modular PSU
Lancool K58 Case
I'll be looking to reuse the SSD, the RAM and the Soundcard. But I'll be after a new Mobo, CPU, CPU Cooler, Graphics and Modular PSU, and a 2T Storage drive. I may also consider a extra SSD ontop of the current one for storage.
Currently I've got as far as this ...
http://www.overclockers.co.uk/showproduct.php?prodid=GX-065-HS - HIS HD 7950 IceQ BOOST 3072MB
http://www.overclockers.co.uk/showproduct.php?prodid=HD-374-WD - Western Digital Caviar Green 2TB SATA 6Gb/s 64MB Cache - OEM
http://www.overclockers.co.uk/showproduct.php?prodid=HS-004-BQ - CPU Cooler
I'm fairly easy in terms of going down either the Intel or AMD route, but I would like the motherboard to be a dark one so it matches the inside of the case and also a full ATX size so that it will look neater as cables will have less distance to travel and more space.
So can anyone help me complete this spec please
AMD FX-4100
M5A78L Asus Mobo
GTX570 PNY
128GB Kingston SSD
Asus DX2 Sound
3 Storage HDD
Lancool K58 Case
