- 26 Feb 2007
- Blackpool
Posted this in both cooling and Graphics Cards as i'm not too sure which is the right area (dont hate me
So i upgraded my fans in my case as my three GTX 580's were overheating.
After fitting the new fans, upgrading the standard ones, fitting a fan controller, modifying the backplates on the cards so they have a wider opening allowing hot air to escape quicker more efficiently and fitting a fan to the back of the graphics cards so it pulls hot air from the cards.
Here are some pictures:
msi Afterburner (If you can't see the temps on Afterburner they are 101c for the top one, 85c for the middle one and 60c for the bottom one).
Side Fan and Inside Case
Fan Controller
80mm Fan at the Rear of the Graphics Cards (pulling hot air away from them)
As you can see after playing Batman Arkham Asylum with all of the fans in the case including the GPU ones at 100% my tempurate of GPU1 is still sitting at a dangerous 98c...
Any last suggestions before i consider watercooling? I have made sure i have the GPU's apart from each other as much as possible however due to the SLI bridge and the motherboard they are still sandwhiched tightly together.
Thanks,
Shep.
Fan Controller
Thanks,
Shep.
