I'm in a dilemma, over which 970 to go for, I've only got one requirement it needs to have triple fans, with the centre fan being on blow, and the 2 outer being on blow, I'm going to be using the Silverstone TJ08, and with it being reversed, and inverted, the only air flow will be from the front 180mm AP fan.
With this in mind there are only 2 to choose from, the Inno 3D iChill Air Boss, this has the advantage of the 4th fan on the edge, but my god it's fuggly, it would need a bit of a tart up, to make him pretty. Or the ( my favourite ) Zotac Amp extreme, which I think looks dam sexy, well with the lights of any way. They are both the same price, that's with the price match 5UB has sorted out, well done OCUK.
The Zotac has 2 selling points, you can use their software to turn the lights off, and with it taking 2 x 8 pins rather than 2 x 6 pins, the OC'ing potential seems to be better. So Ideas on a postcard please guys.
