Help me decide on these builds please!
28 Mar 2023
Leeds
Hey all - which of these two builds do you think would be best for me to go with? Also any fine tuning, or recommendations / tweaks much appreciated also!
AMD - ITX Build:
CPU: AMD Ryzen 9 7950X3D 4.2 GHz 16-Core Processor
CPU Cooler: ARCTIC Liquid Freezer II 240 56.3 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX B650E-I GAMING WIFI Mini ITX AM5 Motherboard
Memory: G.Skill Trident Z5 Neo RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory
Storage: Crucial P5 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Video Card: Sapphire PULSE Radeon RX 7900 XTX 24 GB Video Card
Case: Cooler Master MasterBox NR200P Mini ITX Desktop Case
Power Supply: Corsair SF750 750 W 80+ Platinum Certified Fully Modular SFX Power Supply
Case Fan: Phanteks PH-F120T30 67 CFM 120 mm Fan
Intel / 4090 Build:
CPU: Intel Core i7-13700K 3.4 GHz 16-Core Processor
Motherboard: Asus ROG STRIX B760-I GAMING WIFI Mini ITX LGA1700 Motherboard
Memory: G.Skill Trident Z5 Neo RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory
Video Card: MSI RTX 4090 VENTUS 3X 24G OC GeForce RTX 4090 24 GB Video Card
Power Supply: Silverstone SX1000-LPT 1000 W 80+ Platinum Certified Fully Modular SFX Power Supply
Will be a 100% gaming rig. And I'm more of a 'plug and play', rather than tinkering / optimising (without help).
I was all set on the AMD 7900XTX / a new X3D build (have purchased everything, so if I got Intel I will need to exchange some parts) but the cost / supply / conflicting online reviews has just all become a little stressful and time consuming. So I've just thought, with a little extra budget could I just do a Intel / 4090 rig? At this point I just want to get something built.
I'm by no means a pc expert, and usually go off recommendations / research / and surface level knowledge. We're talking YouTube benchmarks to see performance in games I play and reviews.
I will also be getting this built by someone else. Any help / input much appreciated.
Cheers!
I would add at least another 2TB storage drive while you are getting it built as with the size of games today I quickly run out
