Help me decide...
12 Dec 2005
I want to buy a PC Monitor for Xbox 360 gaming however I don't have a huge budget. Around £110.
In my local PC shop, I noticed they have an AOC 24" for £105. The specs are below.
Would I be best buying this or should I attempt to get a used one from members market and maybe get a bit more for my budget?
Cheers
I noticed the AOC monitor has a contrast ratio of 60000:1. Other monitors have a much higher contrast ratio, what's this mean exactly?
That's dynamic contrast ratio, ignore it, they just make it up as they go along and you won't be using dynamic contrast anyway.
i was in the same boat as you last month then i decided to go for the BenQ G2420HD (non-LED) for £130, and im loving it, still tweeking it to get the right settings though :)
