Help me decide :(
20 Dec 2011
Aberdeen
I recently received a Asus PB278Q which I love, and I was a little worried my GTX 560 DCII couldn't cope, but alas it is getting on fine.
However I am about to get another PB278Q, mainly coz there awesome and I might as well have matching monitors on my desk.
Think this will make my GPU freak, so I would like to upgrade, anyone have any recommendations without breaking the £300 mark? I am a little lost in the current choices available. Mainly used for Warcraft and live streaming (something I am struggling with slightly atm, not a huge amount, but could be smoother)
cheers :)
WoW is CPU dependant and so is streaming, in fact to stream really well you're meant to use a capture card or a seperate device such as another PC.
For your budget though I'd recommend a 7970ghz edition. You could wait for new series but both top end cards will likely be above £300.
Its more for the 2556x1440 res that I would be running on both monitors. Capture card is in the post :D its been there for the last 4 days :( damn you TNT!
I should also mention I am a Nvidia kidna guy :D
