Help me diagonse Win7 freezing problem please!
11 Jan 2005
London
Just rebuilt my HTPC with an AMD 240e processor on a Asus M4A785TD-M EVO mobo, 2gb of DDR3 ram and an ATI 5670.
Having big problems with it though, firstly getting it to install, which I eventually tracked down to my Logitech nano mouse receiver, which when plugged in frequently caused the installation proggie to freeze at various points. Once I had that sorted I had everything up and running but the system seems v unstable coming of S3 sleep mode.
The problem manifests itself in a complete system freeze, usually 15-30mins after coming out of sleep. Initially everything seems fine and I can play music, watch videos, record TV etc, but then the whole system just locks up. No response from mouse or keyboard, can't access it over the network etc. Doing a hard reset often results in Win7 freezing at the "welcome screen" with another hard reset required.
Usually 1 or 2 resets will get it to boot sucessfully and then everything is back to normal until the next time the system goes into/out of sleep mode and the above starts happening again.
Any ideas how I can pin this down? Nothing in the event logs, virus scan shows nothing, and I'd be amazed if it was a heat problem given the decent airflow in the case and the low power processor.
Any ideas much appreciated. Guess I could run some sort of coretemp monitor to rule that out, is there something similar for gfx cards? But as I said I think it's connected with sleep mode and I don't really want to leave this box on 24/7.
Don't know if this will help but I had random system lock ups which I finally tracked down to my wifi card/its drivers. Since removing it the system works fine.
There have been many reports of Win 7 lockups all over the net and almost everytime is down to device drivers or lack there of.
My own freezing problem was caused by an out-of-date motherboard bios, which once updated removed the conflict with the hard drive controller.
It almost certainly will not be a heat issue, make sure all of your drivers (inc. motherboard devices) are current and the motherboard bios is current.
If you're overclocking the system set everything back to stock levels and make sure you're ram timings are correct if you've changed them from automatic.
A useful forum for other ideas is :
http://social.technet.microsoft.com/Forums/en-US/categories
Thanks for the replies. I'm running the latest bios as that was the first thing I tried, and other than the cool and quiet type options and disabling the onboard gfx I'm running everything on stock settings in the bios.
Quite hard to figure out if it's a driver conflict as W7 isn't showing any errors in anything!
what drivers are you running on ur 5670 i have a 5850 and my windows 7 kept crashing randomly on the 10.2 drivers so i tryed the 10.3 beta drivers still done it so i went back to 10.1 and no proplems since a lot ppl been doing the same thing. So try 10.1 drivers and let us know
