Hey Peoples
Looking at shrinking my current rig down to a mini-ITX board, but need a bit of advice on the best way to go about it. I currently have the following.
CPU: AMD Phenom II x3 720
RAM: 2x2Gb of DDR2 cant remember the make or speed
GFX: Nvidia 470GTX
So I'm not sure what the easiest route would be is there any ITX board that would accomadate my current rig, or would i be better upgrading things, Ideally i didn't want to spend too much doing it.
For a case I was looking at the Sugo SG05. I basically want the smallest case i can get my gfx card along with 1x HDD and 1 x SSD in.
Also the ITX board needs to output standard 5.1 as well as an optical output at the same time if possible
GFX: Nvidia 470GTX
