- 8 Oct 2007
Hello, i have a problem with over clocking my E2180. I am running it on a P35C-DS3R and cooling it with an Arctic Freezer 7.
It boots at stock, on stock voltage to give me 2.0ghz. I gained some new ram this morning from Ocuk (geil 6400 ull 2gig). My old ram was Corsair Value Select
4gig 4300. I can get this baby to 3ghz (thanks to Will Hub
) at 8 X 380 at 1.45V. 33oc (i) / 65oc(l). Which in my opinion seems a bit high as other people get 3ghz at stock voltage! Ive also spoken to Ikettles about this problem giving me various things to test out. I found out that my computer will not boot at 7X300 (2.1ghz) at 1.45v :/.
Using my old ram i could achieve 2.6ghz with 10 X 265 with my Timings tight Cas4. Using this new ram i have to use cas5 when attempting to hit 3ghz. I have read the guide about upping the MCH and FSB up by +0.1V or .01V what ever it is. My ram ratio is set at 1.1.
Any ideas how i can get to at least 3ghz if not beyond on a lower voltage than 1.4V?
Thanks,
Paul.
) at 8 X 380 at 1.45V. 33oc (i) / 65oc(l). Which in my opinion seems a bit high as other people get 3ghz at stock voltage! Ive also spoken to Ikettles about this problem giving me various things to test out. I found out that my computer will not boot at 7X300 (2.1ghz) at 1.45v :/. Using my old ram i could achieve 2.6ghz with 10 X 265 with my Timings tight Cas4. Using this new ram i have to use cas5 when attempting to hit 3ghz. I have read the guide about upping the MCH and FSB up by +0.1V or .01V what ever it is. My ram ratio is set at 1.1.
Thanks,
Paul.
